vcProcessManager
The process manager service automatically creates, updates and removes process groups when process implementations are added, renamed or removed within its parent process controller. The process groups can be used to easily find all implementations of a process.
Referenced by: vcProcessController.ProcessManager
ProcessGroupsvcList[vcProcessGroup]RGets an observable list of all current processes in this process controller.
changeGroupIdNonevcProcessGroup group,
String newId
Tries to rename a process i.e. change id of all process implementations in a process group.
group (vcProcessGroup): The process group to change the id of.
newId (String): The new id.
ValueError: When the new process id is empty.
ValueError: When the new process id already exists in some executor's processes.
findProcessGroupvcProcessGroupString processIdTries to find a process group that contains all processes with the given id.
processId (String): Id to search for.
vcProcessGroup: The found process group or None.
NameParametersDescription
OnGroupIdChangedvcProcessGroup group,
String previousId
Triggered when all processes within a group changed their id.
group (vcProcessGroup): The target process group.
previousId (String): The group's Id before changes.
OnProcessAddedvcProcessRoutine process,
Triggered when a new process implementation has been added.
process (vcProcessRoutine): The target process routine.
OnProcessRemovingvcProcessRoutine process,
Triggered when a process implementation is about to be removed.
